Fonction "COMPARE"
waligator
Has thanked: 5 times
Been thanked: 7 times
Fonction "COMPARE"
Post by waligator »
Hi all,
I think it is a bug in the "COMPARE" string!
If the variable "Test" is rec, with writing below, the answer must be 0. As the third parameter is "1".
Return = Compare$ (Test,"REC",1)
With V5, the response is reversed.
Can you check
thank you
JonnyW
Has thanked: 63 times
Been thanked: 290 times
Re: Fonction "COMPARE"
Post by JonnyW »
Good evening. If the variable Test="rec" then this should return '1' - the flag is for 'case insensitive' according to the help file so "REC" and "rec" are seen as the same.
However I have only tested this in simulation but have looked at the C code for the compare and this is as expected. Can you confirm simulation is where the issue is or is it on the chip?
Jonny
waligator
Post by waligator »
Hello Jonny,
In the help file:
Str1 = "ABC"
Str2 = "abc"
RetVal = Compare$(Str1, Str2, 1)
RetVal is now 0 as when case insensitive the two strings are identical.
In my example:
Test = "rec"
the variable "Return" should contain "0" as in the example above.
but the variable "Return" is "1"
Simulation and real is the same
JonnyW
Post by JonnyW »
Morning. Yes, you are right - I was thinking return '1' for match, '0' for mismatch but the function should return 0 for match.
In simulation this is because the check for the case insensitivity is missing (so checks are always case sensitive) - this will be fixed for v5.2, and apologies for this. If you wish for simulation to be OK, the only real workaround is to use the ToUpper$() and ToLower$() functions to force the case then do a case-sensitive check.
On HW, we created a simple file (attached) and this outputs as expected. It outputs '1' in simulation, but '0' on hardware, so it seems the bug is simulation only.
example_01.fcf
Simple compare
(6 KiB) Downloaded 281 times
Cheers,
Jonny
waligator
Post by waligator »
Ok
Pending V5.2, I'll change my project accordingly.
thank you for your check.
