EB006 with PIC16F88 - Keypad problem
Phaenix
Has thanked: 4 times
Post by Phaenix »
I think I may just be doing it wrong, but I've been breaking my head over it for a while now... I was using this for this configuration/testing strategy: Keypad Board C & Assembly Strategy
#include <system.h>
void setup_hardware(void)
	trisb = 0xF0;
	trisa = 0xE0;
	porta = 0x00;
void main(void)
	setup_hardware();
	while (1)
		portb = 0x01;
		if ((portb & 0x10) > 0)
			porta = 0x01;
		else if ((portb & 0x20) > 0)
			porta = 0x04;
		else if ((portb & 0x40) > 0)
			porta = 0x03;
		else if ((portb & 0x80) > 0)
			porta = 0x05; // '*' is pressed
		portb = 0x02;
			porta = 0x02;
			porta = 0x05;
			porta = 0x08;
			porta = 0x00;
		portb = 0x04;
			porta = 0x03;
			porta = 0x06;
			porta = 0x09;
			porta = 0x0B; // '+' is pressed
Only buttons 1 - 6 are being read, and buttons 1, 2 and 3 don't always read exactly right.
Puddy32
Has thanked: 1 time
Re: EB006 with PIC16F88 - Keypad problem
Post by Puddy32 »
Just a possibility, have you a ground wire on keypad
if you are getting different readings then some of your connection could be floating.
Phaenix
Post by Phaenix »
There are no connectors on the keypad to ground it, not like the switch board has.
Phaenix
Post by Phaenix »
Does anyone know...? :(
Your not giving us much to go on. When you say don't always read exactly right how do you mean?
Are you using a Matrix Keypad E-block or your own hardware?
Phaenix
Post by Phaenix »
I'm using the Matrix keypad. When I press a button, the corresponding LEDs are supposed to light up. It only does that when I press buttons 1 through 6, 7 to # don't work at all.
When I press buttons 1, 2 or 3 the LEDs lit up, but sometimes they're not the right ones, or too many lit up.
I'm sorry if I'm being confusing... :(
EDIT: this program's purpose was to test the functionality of the keypad. To see if all buttons were working, and to see how they worked exactly. I think I'm doing something wrong.
Please refer to the attached C file and it should help you to get the keypad working. I have replicated your setup with the keypad on PortB and the Digits being shown on PortA.
keypad.c
(5.69 KiB) Downloaded 366 times
Phaenix
Post by Phaenix »
Sorry to be a nuisance, but my school hasn't provided me with Flowcode and I don't think they're going to give me one of the licenses they have. Is it possible for you to give me a solution that doesn't require Flowcode headers?
The C file is just for an example so you can design your own functions. No Flowcode headers are required anywhere in the actual code.
Phaenix
Post by Phaenix »
Ah, alright. Thanks a lot!
