gLCD 4D Macro does noot compile
beambase
Has thanked: 6 times
Been thanked: 8 times
Post by beambase »
I have done a program to test the EB076 E.Block. It runs in simulation but when I try to compile I get the following errors:
gLCDTest2.c
Starting preprocessor: C:\PROGRA~2\Flowcode\v5\Tools\boostc\pp.exe gLCDTest2.c -i C:\PROGRA~2\Flowcode\v5\Tools\boostc\include -d _PIC18F4550 -la -c2 -o gLCDTest2.pp -v -d _BOOSTC -d _PIC18 -d _CHAR_INDEX
gLCDTest2.c(327): error: missing right paren
gLCDTest2.c(327): error: general error
gLCDTest2.c(327): error: variable name expected
gLCDTest2.c(327): error: unexpected constant
gLCDTest2.c(327): error: failure
failure
.....Return code = 1
Any idea what this is and how to fix it?
Edit:
This happens when E-Block EB076 or EB071 is selected. With other E-Block modules it works.
DavidA
Has thanked: 58 times
Been thanked: 258 times
Re: gLCD 4D Macro does noot compile
Post by DavidA »
I think there is some updated C code to come when the 4D displays get their official release shortly.
beambase
Post by beambase »
Oh.. I thought it wa released since you can buy the EB071 in the webshop.
Any idea how long it will take before the 4D displays are released?
DavidA
Post by DavidA »
Hopefully by the end of the day :) if not the week for sure.
beambase
Post by beambase »
I see that you have added some more of the 4D displays to the webshop.
Is the updated gLCD component available for download somewhere?
DavidA
Post by DavidA »
Hello beambase,
here are the updated c files.
Put the one with CAL in the title into the CAL folder, then the other 3 go into the components folder, maybe wise to make a backup of the old ones.
4Ddisplay.zip
(23.71 KiB) Downloaded 369 times
beambase
Post by beambase »
Yes.... it kind of works. I can compile and run projects that is using the 4D displays. But then I try to compile a projec that has the RS232 function in it, it fails and I get a lot of error messages abot unsigned charachters. Switching back to the old CAL file solves the problem. But then compiling 4D projects fails.
Yes we know about this problem and hopefully there will be an update release for Flowcode PIC shortly. Do you need to be able to compile to the 4D displays yet?
If you do then we can maybe provide you with the updated CAL and RS232 component set to solve all the problems.
beambase
Post by beambase »
Yes it would be good. I havea project that will use both the 4D display AND RS232component.
beambase
Post by beambase »
any news about the updated c file that works both with the 4D displays and the RS232 component?
Can you estimate when it will be released for upload?
We have a full update release on the way but for now here are the files to get you up and running.
v5 Serial Comps Update.zip
(139.76 KiB) Downloaded 331 times
