Hi!
Is it possible to use other GSM module than the EB066? There's a lot if you look at the market. If you look on the EB066, it looks to the substantive set some components, possibly a processor that sits on the card that does some work. EB066 is certainly helpful to start with. I saw second modules that are with SIM card or without built in-(GC864PYT730-011; GM862QUD730-009 ..). Will there be much more complicated building programm for such modules? Is there anyone who has tested other modules?
Thank you and Best Regards!
Dmitry
GSM module
Dmitry Maximenko
- Flowcode V4 User
- Has thanked: 9 times
- Been thanked: 2 times
Re: GSM module
All GSM modules should work in pretty much the same way and should support the same set of AT commands. You may need to check the Baud rate of the serial connection as Flowcode currently expects 9600bps. A program that works with the EB066 should work with most other GSM modules.
