I tried to use the webserver component but get errors at compile.
The compile to C works, but the compile to hex fails.
To avoid any errors i tried to put the webserver initialise only in a flow showing the same result :
16F887A_WebServer_Test1.c(1162:24): error: unknown identifier 'RX_PTR_BASE'
16F887A_WebServer_Test1.c(1162:24): error: invalid operand 'RX_PTR_BASE'
16F887A_WebServer_Test1.c(1162:36): error: failed to generate expression
16F887A_WebServer_Test1.c(1162:36): error: invalid operand '+ '
16F887A_WebServer_Test1.c(1162:55): error: failed to generate expression
16F887A_WebServer_Test1.c(1162:19): error: arguments of 'Internet_WritePtr' don't match the parameters of call
16F887A_WebServer_Test1.c(1162:2): error: failed to generate expression
16F887A_WebServer_Test1.c(1506:54): error: unknown identifier 'RX_PTR_BASE'
16F887A_WebServer_Test1.c(1506:54): error: invalid operand 'RX_PTR_BASE'
16F887A_WebServer_Test1.c(1506:66): error: failed to generate expression
16F887A_WebServer_Test1.c(1506:66): error: invalid operand '+ '
16F887A_WebServer_Test1.c(1506:85): error: failed to generate expression
16F887A_WebServer_Test1.c(1506:28): error: arguments of 'Internet_ReadPtrWithShadow' don't match the parameters of call
16F887A_WebServer_Test1.c(1506:2): error: failed to generate expression
Any ideas ?
Webserver component.
Jump to
- Announcements
- ↳ Announcements
- The Knowledge Exchange
- ↳ Programming Tips & Tricks
- ↳ Freelance Embedded Engineers
- ↳ Article Discussion
- Microcontroller Programming
- ↳ General Programming
- ↳ Flowcode V9
- ↳ Flowcode V8
- ↳ Feature Requests
- ↳ Bug Reports
- ↳ User Components
- ↳ Flowcode V7
- ↳ User Components
- ↳ Feature requests
- ↳ Bug reports
- ↳ Fixed bugs
- ↳ 8-Bit PIC
- ↳ 16-Bit PIC
- ↳ 32-Bit PIC
- ↳ AVR & Arduino
- ↳ 32-Bit ARM
- ↳ Poll Discussion
- ↳ Flowcode V6
- ↳ Flowcode v6 Beta
- ↳ Bug reports
- ↳ Getting Started
- ↳ User Components
- ↳ Bug reports
- ↳ Flowcode V5
- ↳ Flowcode V5 Issues
- ↳ Flowcode V5 Suggestions
- ↳ Flowcode V5 Free Edition
- ↳ Flowcode V4
- ↳ Flowcode 4 Bugs
- ↳ Flowcode 4 Suggestions
- ↳ Flowcode V2 & V3
- ↳ General / Misc
- ↳ Components (Comms)
- ↳ Components (Other)
- ↳ Bugs / Application Errors
- ↳ Suggestions
- ↳ BTEC Unit 6
- ↳ C and ASM Programming
- ↳ E-blocks
- ↳ Formula AllCode
- ↳ Formula Flowcode
- ↳ MIAC
- Language Support Forums
- ↳ Deutsch Support-Forum
- ↳ Forums d'aide en français
- ↳ Foro de soporte español
- Other Matrix products
- ↳ Electronics products
- ↳ Matrix Online Courses
- ↳ Other products
- ↳ CoCo
- Hidden
