Nokia 6100
rocket200
Has thanked: 11 times
Been thanked: 3 times
Nokia 6100
Post by rocket200 »
Is it possible to interface the Nokia 6100 with the flowcode 4 gLCD component?
Here is the lcd: http://www.sparkfun.com/products/569
Thanks!
Re: Nokia 6100
That looks very much like the LCD we used to supply on the EB043 v1 board so yes I would think the display should be compatible. I seem to remember there were about three variations of the display made by different manufacturers but they should all work with the component code. There may be a possibility that the contrast is inverted on your display. I think this is a simple command change to fix if this is the case.
