Timer interrupts missing on V5.0 - V5.2 12F series
Attached are some FCD files that will enable timer interrupts on some 12F series targets
E.g with 12F675 Timer 1 is not selectable
With 12F615 & 12F617 timers 1 & 2 are not selectable.
If 64bit windows go to C:\Program Files (x86)\Flowcode\v5\FCD
or
If 32bit windows go to C:\Program Files\Flowcode\v5\FCD
Repace existing files with ones attacted.
12F615.fcd
(9.26 KiB) Downloaded 368 times
12F617.fcd
(9.6 KiB) Downloaded 373 times
12F675.fcd
(6.82 KiB) Downloaded 412 times
Re: Timer interrupts missing on V5.0 - V5.2 12F series
Thanks Martin,
I have added these missing interrupts to the FCD generator so the fixes should be there next time.
Chet
Has thanked: 2 times
Post by Chet »
Could you help me with a fix for the 12F683 I need Timer1 to work in the worst way, thanks!
Hello Chet,
Please can you give the attached v5 FCD file a go and let me know how you get on.
12F683.fcd
(9.32 KiB) Downloaded 387 times
Chet
Post by Chet »
Thank you! I got it loaded will test with some code later. Off topic but can I copy and paste code from one FC macro into another without issues?
Chet
Post by Chet »
It works! I actually ended up using TMR2 as TMR1 has no resemblance to TMR0. On a side note, It seems that in View Chip mode, pin simulation does not match LED activity on a given pin. Thank you.
