Eprom Problem
wayne millard
Has thanked: 7 times
Been thanked: 12 times
Eprom Problem
Post by wayne millard »
Hi Team,
Is there a problem with writing to Eprom on a 18F4520 i can read the data but when i write data then read what is there i always get 255.
Thanks :D
Re: Eprom Problem
Hi Wayne,
Hm possibly :) I will see if I have one of those devices available for testing.
Have you tried writing to different locations to see if it is just a problem with a single address location?
Re: Eprom Problem
Just had a go with a 18F2520 device and the EE memory is working fine with FC v5.2.
I've also checked that the Flowcode definitions for the 2520 match that for the 4520 device.
Here is the test program I used. Should be quite good for testing the EE memory on any device as long as you have a LCD connected to the system.
EEPROM_Test.fcf
(10.5 KiB) Downloaded 294 times
