Expansion PCB
This PCB is designed to provide extra proto typing space for the 18,28,40 way
Proto type PCB’S (40 way item is not completed) but goes on same lines as 18 & 28 way item, The PCB connects to the other pcbs via a ribbon cable fitted with IDC Dill Plug
Farnell part number 1565532. The Leds on the LHS are for Optional indication if req.
The files are made in eagle 6.01 a licence to open 160 x 80 mm files may be required (hobbyist or greater)
Files are compressed with 7-Zip Please change .txt to .7z as a file ext as wasn't allowed to upload attachment
http://www.7-zip.org/
