Prototype PCB’s 18,28 Way
These PCB’s are all very Similar in design and allow for 3.5 or 5 volt dc operation
With a 9 way socket to allow an eblock to be fitted if required.
With a prototyping area for development and terminal blocks for interfacing.
The files are made in eagle 6.01 a licence to open 160 x 80 mm files may be required (hobbyist or greater)
Files are compressed with 7-Zip Please change .txt to .7z as a file ext as wasn't allowed to upload attachment
http://www.7-zip.org/
I Have a version for 40 pin ic's which is to be finished will post when it's done
proto type pcb for 28 pin ic's
Steve001
- Has thanked: 460 times
- Been thanked: 523 times
Re: proto type pcb for 28 pin ic's
opps put incorrect .brd file in folder 2 of the mounting holes are in the incorrect place attached of the correct one
