RGB LED does not work ... at all.
iamwhoiam
Post by iamwhoiam »
Hi there. This is simple. I have a simple "while 1" loop, and inside it, I have set the value "2" to PORTA, and to PORTA is connected an RGB LED... and it doesn't light AT ALL.
Ideas?
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Re: RGB LED does not work ... at all.
Post by JohnCrow »
Are you using the FC5 macro? or writing it in FC4
RGB_Test_V1.fcf
(11 KiB) Downloaded 349 times
This is a flowcode 4 version
Simple RGB.fcf
(4 KiB) Downloaded 335 times
My flowcharts are set to use PortD but it can easilly be moved to Port B
Bit 1 = Red
Bit 2 = Green
Bit 3 = Blue
Dont forget you need a current control resistor for each colour, a single resistor in the negative line is not advisable, even though it may look like it will work :)
iamwhoiam
Post by iamwhoiam »
JohnCrow wrote:Hi
RGB_Test_V1.fcf
Simple RGB.fcf
Bit 1 = Red
Bit 2 = Green
Bit 3 = Blue
Thanks, but I am talking about the limitations and bugs in the software; I have no doubt in the laws of physics. The LED is the simulated one, NOT a physical one.
JohnCrow
Post by JohnCrow »
The RGB led simulates fine in FC5.2
The component is not available in FC4 so has to be simulated using 3 seperate LEDs
Simple RGB V2.fcf
(6 KiB) Downloaded 395 times
It would be easier to see what you mean "it does'nt work at all" if you can post your flowchart.
DavidA
Has thanked: 58 times
Been thanked: 258 times
Post by DavidA »
Hi since this is discussing the RGB component in v5 ill move it to the v5 forums, if you require v5 forum membership please PM me with the last 6 characters of your v5 licence code
