Copy/paste variable
Has thanked: 1135 times
Been thanked: 299 times
Copy/paste variable
Post by jgu1 »
Hi all!
I would ask, is it possible to copy variables from one project to another project.
Understood in that way if I'm making a project (or mix two project) and want to copy something from another FC, I copy the program and put it in FC and the FC says that variables not existing. Is it possible perhaps, in some way first to copy the variables and then flowchart :?: :D
I am not familiare with C.
Thank´s in advance
Jorgen
Re: Copy/paste variable
Hi Jorgen,
If you export a macro, all the variables within that macro will also be exported with it.
If you then use import function on your new flowchart, the variables contained within macro will also get imported,
Export & Import can be found within the macro menu.
If you want to export Main macro, then in Flowcode 5 it's made easier by using the Duplicate macro function.
Just Duplicate to a new macro called Main1 for example, export Main1.
Then on your new flowchart import Main1, highlight all the icons, cut, then paste in Main macro.
Hope this helps
Post by jgu1 »
Hi Martin. :D
Thank´s.
I have tested both of your suggestions. It works fine with export and import of macros. But when I look in the "properties for variables" are the characteristics have not been imported.
There must be something I still doing wrong. But what?
regard
Jorgen
Post by jgu1 »
jgu1 wrote:Hi Martin. :D
Thank´s.
There must be something I still doing wrong. But what? I tested with John Crows "simple thermometer with LM35z" I try to import it in a new project.
regard
Jorgen
LM335Z Local Temperature Display-PortE.fcf
(11 KiB) Downloaded 269 times
I have just checked, and FC5 does not export/import like FC4 does.
You are correct, no variables gets imported at all!
So there is either a different way to do this, or there is a bug with FC5 or this method of importing variables has been deliberately removed?
Shame if the latter.
My guess is a bug?
Only Staff at Matrix can answer that question.
Post by jgu1 »
Ok, Martin! Thank´s for your test. I hope MM staff see this. :?: so for now, the hard way. creating variables
Jorgen
JonnyW
Has thanked: 63 times
Been thanked: 290 times
Post by JonnyW »
Hi. Yes, we've seen this! As I haven't done anything specifically with the import and export for v5, I think this will be a bug. I'll take a look and let you know of anything, though its likely this will be fixed only in v5.3 which I think we will be releasing at the time of the ARM/AVR/dsPIC variants.
Cheers,
Jonny
Post by jgu1 »
Thank you Jonny!
Jorgen
