Unable to configure any parts
Errol
Has thanked: 9 times
Post by Errol »
I'm running Window7 64 bit. FlowCode 4.5, chip 18f4550/16f88, pickit3 programmer
If I select Chip/Configure I get the following display :?
I have reinstalled 4.5 patch. to try to fix this problem
(20.82 KiB) Downloaded 1607 times
Could this be caused by also having Flowcode 5 (free copy) installed.
Any one have any ideas?
Re: Unable to configure any parts
Hi Errol,
No not caused by having Flowcode free version.
All you need to do is select 'Build', 'Compiler options' then select Programmer Tab.
Select 'Use external program to set configuration options'
Then OK.
Now when you Select Build, 'Project options'
Selecting 'Configure chip..' should give you the configuration options your use to
Errol
Post by Errol »
Hi Martin
That was it..I must have un-checked when I setup the PicKit3
Thank You :D
