because no one gives me a hint with my problem when i change from FC4 to FC5 posted in the FC4 Forum http://www.matrixmultimedia.com/mmforum ... 29&t=10703
I will declare it again here in the FC5 Forum.
I built a fine running system in FC4 with the following components:
PIC 16F887
LCD ( 2 lines with 16 characters)
RF module based on the EB063 hardware.
Wrote the software in FC4.
Compiled and programmed the system.
Everything works fine.
Now i have to take some minor changes.
I bought FC5 and, for my luck, i opend the code i a separate directory.
Changed only one delay value.
Compiled to C with no error
Compiled to HEX with no error.
Programmed the PIC and set it into the board.
Absolute nothing works.
Ok, lets try the original code without any changes.
Done the same (compiled and programmed)
Nothing works.
The fact is, that if i take my code, written in FC4, into FC5 and compile it the target is not working.
Where is the the bug?
Is it the definition of the PIC16F887?
Is it the LCD macro?
Is it the RF macro?
I don´t know where to search.
This is very aggravating because i ask myself why i bought a software that is unable to translate code written in an older version.
My FC4 is the latest Version.
My FC5 is the latest version
The Attachments are the C-Files from FC4 and FC5.
Andreas
