Why not:Flowcode USB serial
I want to make a single chip microcomputer and computer communication experiment USB, but USB serial driver installation is always a mistake. As shown in figure. Please help me. Thank you!
- Flowcode USB serial.JPG (7.93 KiB) Viewed 4475 times
Re: Why not:Flowcode USB serial
Have you generated the driver from the USB component properties and then used this driver when installing the USB serial device in device manager?
Yes! Generate and install! As shown in figure。But always not line! Why?
- mchpcdc.rar
- (910 Bytes) Downloaded 268 times
Please can you post up your Flowcode program too and I will have a look through that to see if I can spot anything.
Have you managed to get any USB comms working or are you just starting out with it from one of the example files?
One example. The simulation is good. Download to chip can't run. And put the computer, can't find new hardware. So the driver installation not line! Thank you, help me!
- USB serial.fcf
- (7.5 KiB) Downloaded 254 times
I have offered a solution to the problem here.
http://www.matrixmultimedia.com/mmforum ... 29&t=10801
Let me know how you get on.
