Reading Resistance....
Sparkoids
Has thanked: 30 times
Been thanked: 19 times
Post by Sparkoids »
I want to read the resistance of an three (analogue) potentiometers with a PIC then using a Digital Potentiometers controlled by the SPI bus on that PIC recreate that resistance (doesn't have to be particularly accurate) but done digitally.
Before I go ploughing in does anyone have any code for this type of thing already or any ideas of the best way to proceed please?
Thanks in advance....
James :-}
petesmart
Has thanked: 187 times
Been thanked: 140 times
Re: Reading Resistance....
Post by petesmart »
Hi James,
I have been playing around with digital potentiometers. They are really cool :mrgreen: – microchip sell them.
They can be driven via SPI what I2C, and you can cascade quite a number of them. They come complete with 3 terminals just like a normal potentiometer, I have used values of 5K, 10 K and 100 K
You could use an ADC on the micro to read the voltage on the wiper of your input potentiometer – convert that to a byte - then send that byte value to the (output) digital potentiometer.
Attached is the data sheet url - come back to me if you have any questions
http://www.microchip.com/wwwproducts/De ... e=en010497
http://ww1.microchip.com/downloads/en/d ... 11195c.pdf
good luck
best regards,
Pete
sorry about that Chief!
petesmart
Post by petesmart »
Hi James,
further to my post (a few minutes ago) I have found a code example for you.
It is a 2 channel ADC to dualchannel Digi pot. I have not used this for a while, not sure if it works on the hardware still, however it simulates okay in V5. Note I originally created this in V4.
Have a play and see how you go.. I think this is possibly what you are after albeit only 2 channels. Adding another channel is relatively simple, have a go yourself, I'm sure you can do it. :wink:
All the best,
Pete
dual channel actuator driver.fcf
(21.82 KiB) Downloaded 386 times
Sparkoids
Post by Sparkoids »
Hi Pete,
Thanks for that fella!
Are the Microchip ones easily cascadable?
The only thing that puts me off is that Analogue Devices make one unit that can be a Log or Lin pot but the Microchip is either or...
Thanks again...
James :-}
petesmart
Post by petesmart »
Yes they are easily cascadable
On the microchip site there is an application note, which describes in detail how to address multiple devices...
I have not had any experience with AD ... Looked at them briefly, then chose microchip...I can recommend the MCP solution.
Best
Pete
Sparkoids
Post by Sparkoids »
Hi Pete,
Well your code seems to be exactly what I'm looking for on the channels.
All I need to do it appears is set up two outputs to those digipots and it should be it...
Thank you again - if I have something to start with I find it easy to mess about and hack something together. And then people on this board who are very helpful clean it up for me!
Thanks again....
James :-}
petesmart
Post by petesmart »
Hi James,
Thanks for the feedback....I used this code to drive a large industrial machine....please be aware that the code needs the appropriate level of error checking if you are going to use it in mission critical situation.
Can you post back your final result/outcome of you project...I am very interested in the end result.
All the best,
Pete
Sparkoids
Post by Sparkoids »
Hi Pete,
Nothing industrial here!
Thanks for the info - I will let you know how I get on....
Best regards,
James :-}
Spanish_dude
Has thanked: 63 times
Been thanked: 102 times
Post by Spanish_dude »
Best way I can think of is using a constant current and measure the voltage with an ADC.
Nicolas
