I've trouble reading and writing to the eeprom of my PIC18F8722.
I wan to write a value of 296 to the eeprom, this is a value of a calibration process.
but when I read the same address the result is different.
Also I have tryed to write to address 1 instead of address 0 but same result.
Can some body look into this, because this setting cannot be lost after power-down.
And then there is a switch problem this is a snap-shot of a macro that i'm using for my calibration menü:
as you can see here that I can use my rotary encoder to select the different sensors when I press the rotary encoder""ROT_SW" then its should enter that sub menu of sensor CO2 bt it never does, When I hold down so ROT_SW remains High end then rotate the encoder to select sensor CO2 then it enters the submenu, I dont know how where this behavior comes from because I used the same system in every menu and there it works perfectly.
Hope somebody has suggestion for this solve,
Regards Jordy
