Pins from various ports for 7 segment display
I am using demo Flowcode for PIC V5.2. I am using pic16f676 to drive three 7 segment digits. My problem is that pic16f676 has two ports each of six pins. That mean if i assign portc.0 to segment A , then i am left with segment G and Segment dot as unconnected. If i try to connect these pins to PortA then all pins of from Segment A to Segment F also change to PORTA. Is there any solution for this?
Best Regards
yosuafzai
Best Regards
yosuafzai
- Enamul
- Has thanked: 271 times
- Been thanked: 814 times
Re: Pins from various ports for 7 segment display
HI,
It has solution but it will take time as we have to change
C:\Program Files (x86)\Flowcode\v5\Components\FC5_PIC_7seg.c
Enamul
Edit: I have changed the file to have that effect but still can't sort out it...seems it's an ocx issue..
Enamul
Any clue how to change this file?
Best Regards
yousafzai
Best Regards
yousafzai
- Enamul
I have manged to do it for you in c code..but everything in c code in supplementary code..even the connection of 7segment as FC is not allowing you to use different port for different segment although this PIC 16f676 doesn't have 8 bit in any port..a pain!!
I have mentioned the connection I have used..you can change that according to your requirement in the supplementary code..which is in FCV5 in Build>project options>General options..
I have used common anode as display type but you can change that in the beginning of code..1 for common anode and 0 for common cathode
I have shown how to display digit using c code like..
Here 3 is the digit to display and 0 for DP..if you want dp to on; put 1 here.
Although I haven't used clear digit macro but it's implemented, you can use that easily to clear 7segment...By just adding the following code in a c code box..
I have tested the program in Real PIC and so it should work in hardware..
Enamul
#define MX_7SEG_COM_TYPE 1
ShowDigit(3,0);
ClearDigit();
Enamul
Yes unfortunately this is a limitation of the VB OCX file. You can work around by hardcoding the connections using the customise code and editing the connection definitions in the defines function or you can do how Enamul has shown which is to rip out the 7 seg code and instead place a hard coded version into the supplementary code slot.
- Enamul
Hi Ben,
I was looking this issue when you are in leave about changing c component of 7segment to customize the connection. I have edited the c code like LCD which enables us to use different port for different pin. But no success in getting the option in changing pin wise port.
Can you please tell me how to edit the connection definitions in the defines function?
Thanks,
Enamul
Thanks,
Enamul
- FC5_PIC_7seg.c
- (9.61 KiB) Downloaded 585 times
Ok In the defines section for a single 7-seg display we have this code.
It looks like a single port is expected so we can create a new define to hold the second port and hard code the other defines so they work with the properties passed from Flowcode.
Because only one port definition was used previously we need to switch to the new definition when referencing a pin on the new port, in this case pins 6 and 7.
Show digit code.
#define %a_SEG_PORT port%b
#define %a_SEG_TRIS tris%b
#define %a_COM_PORT port%c
#define %a_COM_TRIS tris%c
#define %a_SEG_PIN0 %d
#define %a_SEG_PIN1 %e
#define %a_SEG_PIN2 %f
#define %a_SEG_PIN3 %g
#define %a_SEG_PIN4 %h
#define %a_SEG_PIN5 %i
#define %a_SEG_PIN6 %j
#define %a_SEG_PIN7 %k
#define %a_COM_PIN %l
#define %a_COM_TYPE %m
#define %a_SEG_PORT porta
#define %a_SEG_TRIS trisa
#define %a_SEG_PORT2 portc
#define %a_SEG_TRIS2 trisc
#define %a_COM_PORT portc
#define %a_COM_TRIS trisc
#define %a_SEG_PIN0 0
#define %a_SEG_PIN1 1
#define %a_SEG_PIN2 2
#define %a_SEG_PIN3 3
#define %a_SEG_PIN4 4
#define %a_SEG_PIN5 5
#define %a_SEG_PIN6 0
#define %a_SEG_PIN7 1
#define %a_COM_PIN 2
Show digit code.
if (cSegmentValue & 0x40)
FC_CAL_Bit_High_DDR(%a_SEG_PORT2, %a_SEG_TRIS2, %a_SEG_PIN6);
else
FC_CAL_Bit_Low_DDR(%a_SEG_PORT2, %a_SEG_TRIS2, %a_SEG_PIN6);
if (cSegmentValue & 0x80)
FC_CAL_Bit_High_DDR(%a_SEG_PORT2, %a_SEG_TRIS2, %a_SEG_PIN7);
else
FC_CAL_Bit_Low_DDR(%a_SEG_PORT2, %a_SEG_TRIS2, %a_SEG_PIN7);
- Enamul
In my modified one I have done similar thing which I was thinking for any pic..that's why I have modified for upto 5 ports. But it seems that the component code a bit changed in FCV5.4 although mine one was for FCV5.2.
Enamul
Edit:
ok..I got it..still you can't change port in FC connection window but as it is done hard core..so it will work in hardware and I can see the changes in c code..and good thing is that it simulates in FC. Also I think will work in demo version of FCv5
Thanks al lot Ben. You are real boss.
@yosuafzai
you can back up your c component code for 7 seg and put the attached one in the component folder in FCV5. Now you can put 7seg component in panel and use normally 7segment don't need to connect the component as it is done in c code..
Enamul
Edit:
@yosuafzai
- FC5_PIC_7seg.c
- (7.87 KiB) Downloaded 590 times
Hi Enamul
Thanks a lot. I really appreciate your effort. I will test the code both in FC and in real hardware and will let you know.
Best Regards
yousafzai
Best Regards
yousafzai
Hi Enamul
It works great. I have studied the file that you sent me for single segment and have modified for 4 seg which also works fine.
Thanks a lot for the nice (and timely) help.
- FC5_PIC_7seg4.c
- (8.62 KiB) Downloaded 599 times
- Enamul
Thanks for the head into the code. I am certain others will get help from it.
