Hello all,
After some searching here and elsewhere, I've failed to find an answer to this. I hope it isn't because my question is so stupid!
Anyway, here goes: is it possible to have MPLAB v8.80 recognize the HP-488 in the Select Programmer pull-down menu? I thought it might be fun to learn about MPLAB using my HP-488 board.
Many thanks,
Thomas Henry
Using HP-488 with MPLAB
- DavidA
- Has thanked: 58 times
- Been thanked: 258 times
Re: Using HP-488 with MPLAB
Im not sure tehre is a way to do this, as I beleive there is no ICSP header on the HP488 board, something i would imagine we will put in, in a later revision of the board. You should be able to create a program in MPLAB, compile to hex then program the HP488 with PPP.
- JohnCrow
- Has thanked: 364 times
- Been thanked: 716 times
Hi Thomas
I have used my HP488 in this way. (Before I discovered flowcode
The hex code generated in MPlab will program into the device using PPP fine
Though I did tend to prefer to use MPASM, to compile the assembler to hex.
Thomas Henry
Hi again,
Thanks guys. In MPLAB there is a pulldown menu that shows a variety of programmers that can be selected. What I was hoping for was a way to make the HP-488 show up in the list and have it invoke PPP automatically. In other words, it would be neat to program chips without ever leaving MPLAB. It would be great if MPLAB provided a "hook" which allowed other burners to be installed.
I gather, John, from your comment that in fact you assembled the .hex code in MPLAB, but then exited and invoked PPP on it's own to burn the micro. Is that right?
Thanks again,
Thomas Henry
Thanks again,
Thomas Henry
- JohnCrow
Hi Thomas
Yes, basically thats what I did when I first got the HP488.
Though i used MPASM which is a simpler (and much smaller) program than the full MPLAB that just does assembler.
PPP should program the pic with hex code from any source as long as its a compatable device.
The HP488 is a great versatile board, nice and compact.
Spanish_dude
- Has thanked: 63 times
- Been thanked: 102 times
There's a way to execute a command line after compiling the code so the code is automatically sent to the PIC.
Just like Flowcode does it, but it's not that great. If you do it like this, it's executed every time you compile.
Nicolas
Nicolas
