-BC:\Program Files\Matrix Multimedia\Flowcode V5\Tools\PICkit2\ -PPIC%p -F%f.hex -M
This line baffles me, why is there a "-B in front of C:\Program files\...
The line above is in the Parameters field.
Under location I have this line:
C:\Program Files\Flowcode\V5\Tools\PICkit2\pk2cmd.exe
Which looks correct and the pk2cmd.exe is there where it belongs
But i always get the message
Flowcode was unable to transfer the flowchart to the microcontroller. Check the programmer options and physical connections.
Using pickit2 as programmer was working, not working Now
markus747
- Has thanked: 26 times
- Been thanked: 2 times
Re: Using pickit2 as programmer was working, not working Now
Just discovered that there is another error listed :
C:\Program Files\Flowcode\V5\Tools\PICkit2\pk2cmd.exe -BC:\Program Files\Matrix Multimedia\Flowcode V5\Tools\PICkit2\ -PPIC16F877A -FActive_Low_18.2_serial .hex -M -A5 -R
PK2DeviceFile.dat device file not found.
- DavidA
- Has thanked: 58 times
- Been thanked: 258 times
Hello Markus,
The -B is correct, seems confusing i know but rest assured thats what it should be.
This seems strange are you able to program your hardware with the PICKit2 via its own programmer specifying a hex file to send?
I've spotted the issue.
C:\Program Files\Flowcode\V5\Tools\PICkit2\pk2cmd.exe -BC:\Program Files\Matrix Multimedia\Flowcode V5\Tools\PICkit2\ -PPIC%p -F%f.hex -M -A5 -R
Should be
C:\Program Files\Flowcode\V5\Tools\PICkit2\pk2cmd.exe -BC:\Program Files\Flowcode\V5\Tools\PICkit2\ -PPIC%p -F%f.hex -M -A5 -R
Should be
- DavidA
Ah of course! The file installation location was changed in v5.
