float
- Jordy101091
- Has thanked: 25 times
- Been thanked: 188 times
Re: float
what do you mean by
Regards Jordy
maybe the variable that your are using is not a floating point type.It will not let me select it, maybe im doing something wrong.
Regards Jordy
Tony Brown
- Has thanked: 36 times
- Been thanked: 5 times
Re: float
Basically I'm trying to read the values from the ADC as volts, but I want two places after a decimal point, and looking at other examples on the forum decided to try using the float command, but I cant work out how to select the float command from the list that appears when you select what format (I think this is the correct word) you want the values in.
- Enamul
- Has thanked: 271 times
- Been thanked: 814 times
Re: float
Hi Tony,
Here is a simplest example of using ADC as volt read where ADC is declared as FLOAT variable. But the float variable can't be displayed in LCD as it is as LCD can display BYTE or INT variables. That's why using float to string function I have converted the float variable to string (i.e., DISP_STR). Float variable has precision up to 6 decimal points but the voltage is just up to 2 decimal points that's why I have taken only 2 decimal places using Left string function.
Hope this will help to start.
- ADC_Float.fcf
- (9 KiB) Downloaded 352 times
- Enamul
Re: float
Hi Tony,
Are you looking for 5V range or higher? Number in first decimal place is going up by 1 and in second decimal place by 5 seems in simulation...So do you want to have 2nd decimal point change by 1 as well?
I have changed the Vref =1.25V, You have much finer resolution now..
- ADC_Float_v1.fcf
- (9 KiB) Downloaded 310 times
Tony Brown
Re: float
Hi Enamul I am wanting to read the voltage of a board under test, its voltage is 24V, I am passing this through several potential divider to drop the voltage to 3V = 24V.
This is what I am wanting to read from the ADC and print on my GLCD. This test is quite critical so IO am using 0.1% resistors.
Thanks by the way for the extra flowcode file.
Tony
Tony
- Enamul
Re: float
Hi Tony,
This version is with Vref=5V and I have modified the program so that it can read 0-5v in ADC input but produces output 0 to 40V which represents 3V equal to 24V as you have mentioned. You can test in hardware with normal LCD and adjust the resistor network. I think in hardware you will get finer resolution than simulation.
Hope this will help.
- ADC_Float_v2.fcf
- (10 KiB) Downloaded 316 times
