What happened to the NEW TOPIC for Flowcode V5
Errol
Has thanked: 9 times
Post by Errol »
I need to post a issue/problem in Flowcode V5 but there is no "NEW TOPIC" button that I can find? :?
Is this because I just upgraded from 4.5 to 5?
Here is the problem I have found:
1/3 of the PICmicro Configuration screen is missing. You can try to drag open more of the screen but it will still look the same.
The right side is not visible
Enamul
Has thanked: 271 times
Been thanked: 814 times
Re: What happened to the NEW TOPIC for Flowcode V5
Post by Enamul »
You are registered user in V4 that's why you can't post in V5 forum. You have to upgrade you to V5 forum. You can do that here..
http://www.matrixmultimedia.com/forum_upgrades.php
About your issue..
Which PIC you have tried you didn't mention..can you please mention that and we can't see that in your screen shot.
Enamul
University of Nottingham
enamul4mm@gmail.com
DavidA
Has thanked: 58 times
Been thanked: 258 times
Post by DavidA »
Hello Errol,
have you changed your DPI settings for Windows? When did this change occur? Has it worked in the past or is this a v5 issue?
Errol
Post by Errol »
Thank you Enamul, that did the trick, I should have know better. :D
DavidA changed the DPI and now it looks correct..Thank You (I would think that you would lock the window size and not allow window size dragged open) :)
Enamul
Post by Enamul »
Glad to know that it's now sorted. Welcome to V5 forum.
Enamul
enamul4mm@gmail.com
