The code both for the FCD file and the Interrupt set-up code file appear to have an error:
//Clock
//Interrupt: Enable TMR1
st_bit(intcon, PEIE);
st_bit(t1con, TMR1ON);
cr_bit(t1con, TMR1CS0);
st_bit(t1con, TMR1CS1);
cr_bit(t1con, T1SOSCEN);
t1con = (t1con & 0x0F) | 0x30;
st_bit(t1con, RD16);
st_bit(intcon, GIE);
st_bit(pie1, TMR1IE);
[TMR1]
Name="TMR1"
HandlerCode="#ifndef MX_INTHANDLER_pir1_TMR1IF\n#define MX_INTHANDLER_pir1_TMR1IF\nif (ts_bit(pir1, TMR1IF) && ts_bit(pie1, TMR1IE))\n{\n\t#ifdef USE_FLOWCODE_ICD\n\t\textern char ICD_Interrupt_Enable = 1;\n\t#endif\n\tFCM_%n();\n\tcr_bit(pir1, TMR1IF);\n\t#ifdef USE_FLOWCODE_ICD\n\t\textern char ICD_Interrupt_Enable = 0;\n\t#endif\t\n}\n#else\n#warning "This interrupt has previously been enabled, so the macro <%n> may never get called."\n#endif\n"
EnableCode="st_bit(pie1, TMR1IE);\n"
DisableCode="cr_bit(pie1, TMR1IE);\n"
OptCnt=3
PrescaleOpt=2
MaxTimerOverflow=65536
Opt1="Clock Source Select"
Opt1Cnt=3
Opt1_1="Internal clock (Fosc)"
Opt1_1Val="st_bit(intcon, PEIE);\nst_bit(t1con, TMR1ON);\nst_bit(t1con, TMR1CS0);\ncr_bit(t1con, TMR1CS1);\n"
Opt1_2="Internal clock (Fosc/4)"
Opt1_2Val="st_bit(intcon, PEIE);\nst_bit(t1con, TMR1ON);\ncr_bit(t1con, TMR1CS0);\ncr_bit(t1con, TMR1CS1);\n"
Opt1_3="T1CKI Pin"
Opt1_3Val="st_bit(intcon, PEIE);\nst_bit(t1con, TMR1ON);\ncr_bit(t1con, TMR1CS0);\nst_bit(t1con, TMR1CS1);\ncr_bit(t1con, T1SOSCEN);\n"
"T1SOSCEN" is present which shold be "T1OSCEN". This gives rise to the error:
Interrupt Usart Test.c(433:22): error: unknown identifier 'T1SOSCEN'
Interrupt Usart Test.c(433:22): error: invalid operand 'T1SOSCEN'
Interrupt Usart Test.c(433:17): error: failed to generate expression
Interrupt Usart Test.c(433:13): error: invalid operand '~(1 << ( T1SOSCEN))'
Interrupt Usart Test.c(433:10): error: failed to generate expression
Interrupt Usart Test.c success
failure
Return code = 1
FINISHED
Simply changing "T1SOSCEN" to "T1OSCEN" in both instances solves the problem.
Changing the FCD file is strightforward with a text editor. Not sure how to change the interrupt setup routine other than with the custom code option??
Other knock on effects in the code??
Hope this helps someone.
Mark
