3 led’s display
armagon29
Been thanked: 2 times
3 led’s display
Post by armagon29 »
I built this project using 3 led’s display (OSRAM PD4437) , but I can print only 1 digit at time, How does It do to print more than 1 digit at time, for example send “ CARAMELO” then this word will be print into displays
PD4437 SERIAL V1.fcf
(80.21 KiB) Downloaded 239 times
Re: 3 led’s display
Do you need a macro to work out the size of the string, then loop from 0 to the string length - 1. Each time around the loop you pass a character from your string to the display by using the loop count variable as your array index.
Send_Char_To_Display ( string[index] )
Hope this helps.
armagon29
Re: 3 led’s display
Post by armagon29 »
Dear Sir:
Im afraid , I did something wrong, now noting happen
Could you be so kindly to check my macro
PD4437 SERIAL V2.fcf
(81.24 KiB) Downloaded 268 times
