Some working exemple of MCP23017 code ?
Is there someone who as already worked with this chip with Flowcode ? is it usable and is there any avaible sample code to communicate with it ? Thanx a lot!
kersing
- Has thanked: 553 times
- Been thanked: 1081 times
Re: Some working exemple of MCP23017 code ?
Have you checked this I/O expansion article in the Programming Tips & Tricks forum??
― C.S. Lewis
― C.S. Lewis
- Jordy101091
- Has thanked: 25 times
- Been thanked: 188 times
For my current project "aquarium controller" I'm using a similar chip.
I'm using this chip for controlling the ac outputs.
If you like I can make you a example program of how to toggle the IO
I need to see that I'm only using this chip for outputs and not for inputs.
But he at least you know how to control the outputs.
Regards jordy
Regards jordy
