PWM Channel 2 - 18FxxK80 ** Informational **
Sefi
Has thanked: 9 times
Been thanked: 14 times
Post by Sefi »
I have found a configuration issue with the 18FxxK80 family of MCUs. Although the pin definition of RC2 is correctly labelled in the pins definitions section, this is not the case in the Defines section and hence PWM channel 2 will not work for this family of MCUs.
To make PWM channel 2 work you will need to make the following change:
Change the following line in the FCD file:
Define55=#define MX_PWM_2_PIN 1
to
Define55=#define MX_PWM_2_PIN 2
The following files are affected:
18F25K80.FCD
18F26K80.FCD
18F45K80.FCD
18F46K80.FCD
Cheers
Sefi
Enamul
Has thanked: 271 times
Been thanked: 814 times
Re: PWM Channel 2 - 18FxxK80 ** Informational **
Post by Enamul »
Spot on..Thanks for the correction..
Enamul
University of Nottingham
enamul4mm@gmail.com
DavidA
Has thanked: 58 times
Been thanked: 258 times
Post by DavidA »
Good spot! Ill add this to the list of things to fix!
Thanks for the spot, the problem has now been found and fixed.
FCD_Generate_File.zip
(50.53 KiB) Downloaded 369 times
