Counting Beyond 32767
Any number greater than 32767 does not show correct number on LCD display
Even if Uint (0 to 65535) or Ulong (0 to 4294967295) variables are used.
Here are two flowcharts.
One counts from 0 to 99999
the other counts from 99999 to 0
Using this method with some modifications,the maximum number can go way beyond 99999 if required.
Count down from 99999 to 0.fcf
Created with Flowcode 5
(10 KiB) Downloaded 557 times
Count up from 0 to 99999.fcf
(10 KiB) Downloaded 575 times
donald
Been thanked: 3 times
Re: Counting Beyond 32767
Post by donald »
Hi Martin,
Thank you very much sir Martin for his precious help. :D :D :D :D :D
All the best!
donald
Post by donald »
Hi Martin,
It is interesting to memorize as if power is interrupted, it to return to counting from where it remained and not from the beginning.
Thank you in advance!
Try this Flowchart.
It will write to EEPROM every time seconds are updated.
Therefore seconds from 99999 to 1 are stored in EEPROM
You don't want to keep updating EEPROM with 0 since EEPROM has a writing time of 1,000,000 operations.
Count down from 99999 to 0 + EEPROM.fcf
(13.48 KiB) Downloaded 578 times
donald
Post by donald »
Hi Martin,
Is super what you have created and thank you very much, esteem and respect. :D :D :D :D :D
No problem donald,
Hope it help you out.
leoo
Flowcode V4 User
Has thanked: 41 times
Been thanked: 9 times
Post by leoo »
Hi Martin,
I'm quite interested to see the coding of how to store bigger numbers in EEPROM. Do you have this in a version that I can view with Flowcode 4?
Thanks.
Leo
Hi Leo,
This article should help.
http://www.matrixmultimedia.com/article.php?a=366
Enamul
Has thanked: 271 times
Been thanked: 814 times
Post by Enamul »
Here is Martin's code in Figure format...you can make that in FCv4.
EEPROM_LARGE_NO.zip
(512.63 KiB) Downloaded 488 times
Enamul
University of Nottingham
enamul4mm@gmail.com
