Hi there, I wanted to know if anyone one of you have a flowcode program using the temperature sensor and motion sensor. I'm completely new to flowcode I need some help.
Thank you
Flowcode program for temperature sensor and motion sensor
DylanBalloo
- Flowcode V4 User
- Been thanked: 1 time
Re: Flowcode program for temperature sensor and motion senso
Hi Dylan
As enamul asked in a previous thread, what temperature and motion sensor devices will you be using, if you could tell us then aomeone will be able to point you in the right direction
Dazz
Dazz
DylanBalloo
- Flowcode V4 User
Hello Dazz,
For the motion sensor I will be using KC7783R PIR Module(http://www.rapidonline.com/Electronic-C ... dule-80434) and the temperature sensor I will use either the LM 355A IC or there's a temperature probe known as the "Wide range stainless steel temperature probe" found on matrix multimedia site(http://www.matrixmultimedia.com/product ... PHPSESSID=). Can you please advise me if the choice of sensors are good and how to proceed.
Thank you loads
Thank you loads
Hi Dylan
i dont know those two modules , but the pir looks like a simple 0 to 5v output so should be easy to implement, the temp probe i would pm one of the matrix staff and ask for the specs etc
Dazz
Dazz
- JohnCrow
- Has thanked: 364 times
- Been thanked: 716 times
Hi Dylan
The sensors sold by Matrix have a plug similar to to UK telephones.
They are designed to fit into either the HP488 development board or the EB003 sensor e-block.
Depending if the sensor is analogue or digital the plug has a key on the left or right hand side.
Full details of the probes can be found here
http://www.vernier.com/
I built a basic PIR sensor board last year
Details can be found here along with a flowcode 4 program.
http://www.matrixmultimedia.com/mmforum ... hilit=+pir
