Unable to compile to hex...
TezzaMcTezza
Post by TezzaMcTezza »
I have just upgraded my V5 Home licence to professional but I am now not able to compile my programs to hex.
The compiler message says this at the end:
failure
Return code = -2
Flowcode was unable to assemble the ASM file due to the following errors:
FINISHED
Any ideas?
ScreenTest.msg.txt
(6.7 KiB) Downloaded 201 times
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Re: Unable to compile to hex...
Post by JohnCrow »
Hi Tezza
RAM available:64 bytes, used:115 bytes (179.6%), free:-51 bytes (-79.6%)
If you look at the error message I've posted above, it looks like your code is too big for the device you are trying to use.
You have 64 bytes available but are trying to load 115 bytes.
The fix is to select a PIC with more memory.
Try selecting a larger device in FC and then try compile to hex again.
JonnyW
Has thanked: 63 times
Been thanked: 290 times
Post by JonnyW »
Hello. Did this program compile with enough space on your device with Flowcode free version, then failed on Flowcode professional?
Cheers,
Jonny
