USB connection failed
davet
Post by davet »
Hi all, have an eb006 board. I switched my computer off, turned it on again to do some work and the usb connection has failed. In the device manager it says "unknown device" will not recognise the eb006.
Can anyone help?
Dave
brandonb
Has thanked: 175 times
Been thanked: 173 times
Re: USB connection failed
Post by brandonb »
i've fixed simular problems in past with a registry clean on pc
Enamul
Has thanked: 271 times
Been thanked: 814 times
Post by Enamul »
You can simply unplug usb cable and re-plug it..and also re-install the usb driver for EB006.
Enamul
University of Nottingham
enamul4mm@gmail.com
Might also be worth a power cycle:
Pull out the PSU and USB cable, re-insert the USB and then the PSU.
