5 X 5 matrix keypad
Has thanked: 1135 times
Been thanked: 299 times
5 X 5 matrix keypad
Post by jgu1 »
Hi! :D
I have been lucky to get a couple 5 X 5 matrix keybad, very fine with arrows, and just for good projects. FC handle either 4 x 3 or 4 x4. Does anyone have an idea for how I can use it in FC. I'm missing the one row and coloum in FC
I can imagine I must use a Custom Component, I do not know how this is used and not C. Has anyone an idea and will help with perhaps an little example please. :D
Thank´s in advance.
Jorgen
Enamul
Has thanked: 271 times
Been thanked: 814 times
Re: 5 X 5 matrix keypad
Post by Enamul »
Yes, it can be done by editing in the keypad c code which shouldn't be very tough :)
Enamul
University of Nottingham
enamul4mm@gmail.com
Post by jgu1 »
Hi Enamul! :D
No not for you. You are an expert in programming (also). But I am far from expert :( , but would really like to learn. Yes, I dare scarcely ask you again Enamul, you have many projects and not least for me, hi, hi. but how do I make something by this 5X5 keypad. If I had to do it, I need almost one extra port 5 input, then I think it´s possible. One input for Row and 4 for coulom and then I have to read the input binaer, but this would be a tricky program for that.
Best regard
Jorgen.
Has thanked: 481 times
Been thanked: 699 times
I have attached an idea as a flowcode macro, not tested it, but it should give you a starting point.
Leigh
GetKey.fcm
(11 KiB) Downloaded 466 times
Post by jgu1 »
Hi Leigh!
Thank you. I will test it in the weekend, and you hear from me- :D
Best regard
Jorgen
Enamul
Post by Enamul »
Hi Jorgan,
I have been through the macro Leigh posted..that's really interesting and compact. Please let us know what you are getting from keypad. It is also important to know the default status of column port pins; as if they are normally at high state program will condition will be different than if they normally at low state.
I am attaching here a list of Key value that the macro will return when you press any in any particular row and column.
(9.3 KiB) Downloaded 3870 times
Enamul
enamul4mm@gmail.com
Post by jgu1 »
Hi both!
Yes of course you will get responce. I hope tomorrow. :D
it's the least I can do when I get help from you.
Yes Leigh's program is very interesting.
Best regard
jorgen :roll:
Post by jgu1 »
Hi Both! :D :D :D :D :D
Yaeh, yeah. Perfect.
Testet on a Pic16f876 with pulldownresistor on A0 to A3.
It was faster than I thought to make the presentation in real life.
I big fool. It was a 4x5 matrix. But it does´nt matter, I can save A4.
But it works perfectly. I have connected a display on port C, so I get the values ​​read out and it's something I can use. In this way it is possible to use all kinds of keyboards.
Good, simple and ingenious way. Even I understand the program :lol: Thank you both, for interesting and help again, really greafull.
:D
Best regard
Jorgen
