Rounding String or Float Variables
I though I would develop a different way to round off a float variable.
Using pot you can select number of decimal places (0 to 6)
(21.54 KiB) Downloaded 4896 times
Decimal numbers are basically cut off, and not rounded up or down.
E.g 1.29 to 1dp = 1.2 and not 1.3
Edit: Temp2 with original flowchart is not required, so it's fine just to delete it.
I have updated flowchart with Temp2 removed.
Rounding Float Or String Numbers.fcf
(12.67 KiB) Downloaded 805 times
Re: Rounding String or Float Variables
Hi Steven,
Steven_SS wrote:
medelec35 wrote: I though I would develop a different way to round off a float variable.
How can I open this in flowcode V8 Martin? Thanks
Sorry you can't now, take a look at this post
I'm happy to convert any flowcharts for anyone from any version to version 8.
Edit:
Although you have figured it out and now deleted your post, I will leave this post for anyone else who has V8
Rounding Float Or String Numbers.fcfx
(13.63 KiB) Downloaded 595 times
jadiflow
Flowcode v5 User
Has thanked: 19 times
Been thanked: 16 times
Post by jadiflow »
Can I add my vote that someone fixes this? fround(x,y) doesn't work, instead it work like round(). The floating point number is rounded to the next integer instead of actually rounded up.
If it can't be fixed, maybe indicate in the help file that it doesn't work for PIC processors.
Jan Didden
Linear Audio
