While playing around gsm componenet i get this error. it neither works in simulation nor on real hardware.
Why?
error in sim macro call2
- Enamul
- Has thanked: 271 times
- Been thanked: 814 times
Re: error in sim macro call2
GSM component works fine in hardware..but simulation will not work. If you think you are facing problem in hardware..you can post program so that we can have a look.
- greentech
- Flowcode V4 User
- Has thanked: 10 times
- Been thanked: 2 times
Be a life long or short, its completeness depends on what it was lived for.
I mean it should have worked in simulation as-well. New comps should be "GUI friendly"
im trying this on sim900d hardware.
- GSM.fcf
- (10 KiB) Downloaded 338 times
- Enamul
Sorry for the delay in getting back. It seems you are FCv4 user..But the file doesn't open in FCv4.
- Enamul
Modem should be connected to USART. In hardware USART mode, RC6 and 7 are Tx and Rx so you can't use RTS, CTS in those pin. You can use any other pin for CTS & RTS. Some other problem in the code which I have corrected, you can go for a try. Please let us know how you are getting.
- GSM.fcf
- (12 KiB) Downloaded 303 times
- JonnyW
- Has thanked: 63 times
- Been thanked: 290 times
Evening.
I will take a look at your program and see if we can remove the error message in a future update.
Cheers,
Jonny
I agree - one of the things we hope to address in future versions is improved simulation of components. However for now the components are more focused on working on download so there will be components that do not simulate.I mean it should have worked in simulation as-well. New comps should be "GUI friendly"
Cheers,
Jonny
