Using More than 1 CCP with Flowcode V5
I have posted this so you can see how to use more than 1 PWM component with Flowcode V5.
Attached Flowcharts use 5 PWM components.
Thanks to opieflus for giving me the idea as I thought it would help people who are not sure how it is achieved.
The main thing to remember are:
1) You need to add an additional PWM component for each extra PWM channel your using.
E.g if your using 4 PWMs, you need to add 4 PWM components in total.
2) You must change PWM Channel of every PWM component used.
Also you you have to alter every Period register & and Prescaler divide, so all PWM components match.
If not, when compiling you will see something like:
PWM  using components V1 (1).c(283): PWM prescale value must be the same in all PWM modules
1 errors detected
Error: preprocessing error
failure
....Return code = 1
Although the error message is nice and clear.
PWM using components V2.fcf
(24.02 KiB) Downloaded 574 times
PWM using components V1.fcf
(22.95 KiB) Downloaded 481 times
Has thanked: 1135 times
Been thanked: 299 times
Re: Using More than 1 CCP with Flowcode V5
Post by jgu1 »
Hi Martin!
Very nice and usefull. :D
Jorgen.
Thanks Jorgen.
So long that it helps, especially if you get use to V4 method.
V5 is great, but may be a bit confusing at first.
