I’m trying to make a simple program that has to change the LED flash pattern when a switch is pressed.
I have:
PIC16F690
8 switches (mandatory)
8 Macro LED flash patterns with loops (working)
The goal is when you push switch 2, the program has to start pattern 2 and stay there until for example switch 5 is pressed, then it has to go to pattern 5. And off course when you press switch x is has to go to pattern x. And so on.
I did take a look to: http://www.matrixmultimedia.com/mmforum ... ate#p15115
But I think this is too difficult for this simple program. Can someone help to make this work for two patterns? The rest I will try to do.
Thanks,
Jan
Read switch 1 to 8 arbitrary
- Enamul
- Has thanked: 271 times
- Been thanked: 814 times
Re: Read switch 1 to 8 arbitrary
I think this is the program you are looking for..
- sw_LED.fcf
- (9.5 KiB) Downloaded 721 times
Hi Enamul,
Thanks for helping me.
I'm trying to understand your program but I have (off course) some questions on how to modify it.
As you know, I have 8 macro's with flash patterns and 8 switches. In your program I can't see how you light the LED's when I push a switch. I think this has someting to do with this: LED_PAT1 = 0b10101010
LED_PAT2 = 0b11001100
This code is (now) too far for me
Your program works fine, but I want to call a new flash_pattern macro when a switch is pressed, no matter in what state the running (loop) or macro is. It has to immidialty stop and go to the next switch input.
Something like this:
https://www.youtube.com/watch?v=WfPgZCCfOD0
You can see that when you press the A B or C switch it does the job, no waiting time (loop's, macro) at all. Just push the switch, and a "next new pattern" macro is activated.
- Enamul
You can try this version of the code with macro and earlier LED patterns. Now it is close to the youtube version. Need to press and hold the switch for 1 sec.
- sw_LED.fcf
- (17 KiB) Downloaded 749 times
Hi Enamul,
This is a very nice one. Thank you !
There is one thing I don't understand. In the Calculation you set a Variable with some binary code. Please explain to me how why you do this? This is for me unclear.
Thanks and greetings,
Jan
EDIT: I can see it has something to do with driving the LEDs in the Macro's, but how this work, I cant see it
EDIT 2: I understand it now. When I take a closer look to the binary format and the .fcf file I see that 0b10101010 is nothing else then a defenition on wich led goes on"1" and off "0"
Jan
Hi Enamul, (or others)
I want to ask you one more question, and that is more a technical question.
In all my flash patterns I make use of the Component Macro to flash a led (On / Off). I see that you do this on a other way. This way for flashing the LED’s is new to me, but I understand now how it works.
Please tell me, does it make any difference for the microprocessor what I use ? Your way of flashing the LED’s or the way that I do via the Component Macro.
This is just a technical question, for my learning. If I see something new than I want to know why is this.
Jan
Jan
