Possible two glcd on the same controller?
Jordy101091
Has thanked: 25 times
Been thanked: 188 times
Post by Jordy101091 »
Hi all,
For a application I'm making I need to use two KS0108 graphic lcds
I was wondering if I could interface these displays with the same controller, or do i need two controller for this purpose.
On display is used for displaying information of a variable voltage source and the other is for two fixed voltage sources.
I hope you can help me with this.
Best regards jordy
Re: Possible two glcd on the same controller?
Hi Jordy,
Should be possible. Are you currently able to drive one display and can you post up the code.
Jordy101091
Sorry,
I'm asking this question because I need to design a power supply with 3 outputs.
- Variable 0...30V
- Fixed 5V
- Fixed 3.3V
I have a big GLCD screen here 240x128 but I cannot controllis with flowcode, so I stept over to useing two smaller GLCD screens 128x64.
I think I now how to do it, I need to figure out to controll the chip select pin.
So for:
LCD1:
CS1
CS2
LD2:
CS3
CS4
But can this be modified in flowcode so it would work this way to have 4 different chip select lines.
