I have a problem to read the the ADC inputs on the 18F87K22 wich is mounted on easypic_pro_v7 board.
Everything works but one last problem to solve.
Tried several settings on variable and the ADC settings (also the same settings as in other projects).
I can not get a good steady reading from the input.
I have showed the value of the variable to a LCD and LED.
And it fluctuate rapidly to every direction.
It looks like the value goes several times from 0-255.
But is difficult to read.
When we turn the potentiometer, the LCD -meter has a steady reading from 0 to 5Vdc.
The 18F87K22 works on 5V and the core on 3V3
Have anyone some suggestions I can look at. Thanks
