Search bytes in EEprom (help with project)
MJU
Has thanked: 121 times
Been thanked: 108 times
Post by MJU »
I'm building a Flowcode project and I'm struggling with following item:
In my Eeprom data is stored 7 bytes at the time.
The data starts @ position 0 and the next serie of seven bytes are stored @ position 7 and so on every 7 bytes.
Every serie of 7 bytes start with a byte that contains the number 1.
Now I want to search the Eeprom for a certain serie of bytes and return the starting point IF there is a match.
If there is no match it should also return a message (true/false).
It could be that there are only 3 or 4 series of the 7 bytes in the Eeprom.
For every first byte of a serie this starts at the 7the position from the previous and the first always starts at position 0.
How can I reliable and fast find IF such a serie exists (the serie I'm looking for is in a parameter[7] array-variable), and IF this exists at which Eeprom address it starts??
Any help is welcome..
Jan Lichtenbelt
Has thanked: 128 times
Been thanked: 264 times
Re: Search bytes in EEprom (help with project)
Post by Jan Lichtenbelt »
Dear MJU
Something like this?
Kind regards
Jan Lichtenbelt
Search_7_Bytes.fcf
(15.64 KiB) Downloaded 285 times
MJU
Post by MJU »
Thank you very much!
I'm going to test it tomorrow.
I see in this code: "= 0 // false"
What does the // mean?
Again thanks a lot!!
Enamul
Has thanked: 271 times
Been thanked: 814 times
Post by Enamul »
// is used to comment out anything in C code. Which you can use in calculation box as well to put comment.
Enamul
University of Nottingham
enamul4mm@gmail.com
Jan Lichtenbelt
Dear MJU,
I'm sorry, but the boolean must be set to true (=1) at the first call, instead of false (=0)
Kind regards
Jan Lichtenbelt
MJU
Post by MJU »
Thank you so very much!
