PWM Output on Arduino mega 2560
trisbillers
Has thanked: 3 times
Post by trisbillers »
Hi, All,
I am struggling to get my PWM outputs to work.
I can get a pwm output on Digital Pin 4 (PWM 2).
But when I tire and get any of others to work I am unable to see a pwm output.
I have tried all different PWM channels/ pins and as you can see with the program attached I should be getting the PWM on both Digital Pin 4 and pin 2,
But i am only seeing the pwm on pin4.
I have tried different pins/PWM channels and the only one I can get to work is PWM channel 2 on Digital pin 4.
Could anyone Help?
Tristan
PWMTEST.fcf_avr
(9.5 KiB) Downloaded 263 times
dazz
Has thanked: 474 times
Been thanked: 458 times
Re: PWM Output on Arduino mega 2560
Post by dazz »
I've attached a flowchart that will switch fade an led via pwm ,all channels are set to work at the same time, so connect a bunch of led's to the arduino pwms and all should work
Dazz
PWMTEST all channels.fcf_avr
(35.05 KiB) Downloaded 325 times
trisbillers
HI, Dazz,
Thanks for the replie,
I have tested your program on 3 diffrent boards, and the only pins that are giving me a PWM output are digital pins, 4, 9, 10, 11, 12, & 13,
Any idears?
Tristan
