I used DS18B20 and I got bad results.
The macro does not work in the factory ONE_WIRE use CRC.
Added to the improved macro.
I did not create the macro.
The help from hobbielektronika.hu.
One Wire CRC error
- Enamul
- Has thanked: 271 times
- Been thanked: 814 times
Re: One Wire CRC error
You can try this..it works fine for me.
- 1. Single OneWire device.fcf
- (12 KiB) Downloaded 316 times
Mikat
- Has thanked: 7 times
- Been thanked: 36 times
Hi.
There was bug in the onewire component, I don't know is it fixed yet if it isn't, the solution for FC5 8bit can be found herehttp://www.matrixmultimedia.com/mmforum ... 47&t=11365 (my last post).
At the 16bit, the onewire just acts very weird, I couldn't get it work with Matrix code, not FC4 or FC5..
Mika
Mika
