Recently wrote need program to control reel using 16f887 (upgrade path from 16f877a) but though Ithought I had it perfected, sometimes on start up it runs motor without being able to control it from knobs and switches.
wanted to see if someone would look at my code and see if I am doing any fundamental mistakes.
The 2 things i see it do occasionally is either run undo high or undo low which runs motor in reverse (1 second) to kick out drive train and other times it runs uncontrollably and the only control which seems to function is the off switch.
(Although when it does behave this way it never is not engaged in low or high speed, (solenoid activated) and direction relay is not energized to make reel pull. so it doesn't seem to pose a danger but I need to cure it!
Some times program misbehaves not sure if using variables co
markus747
- Has thanked: 26 times
- Been thanked: 2 times
- ML- REEL 16.31_887 .fcf
- (99.63 KiB) Downloaded 240 times
Re: Some times program misbehaves not sure if using variable
Hi Mark,
I have just compiled your flowchart, and saw this in the compiler messages:
So the stack exceeding 8 and stack corruption could be causing the issues your facing.
Whenever a flowchart is compiled it's always wise to check Call Stack Usage Report
so with the first issue, you can either rearrange your flowchart to reduce stack usage.
Or increase software stacks. see:
http://www.matrixmultimedia.com/mmforum ... 165#p38548
Or use a chip with more hardware stack.
As for stack corruption .
Most common cause is having same component within an interrupt that you have in a non interrupt part.
E.g Anything congaing delays: LCD, Delays themselves RS232 etc. Mod function.
I will see if I can track down the cause of stack corruption and let you know my findings.
Building CASM file
Serious Warning: Call stack usage exceeds:8!
main and Task(s): hw used:4, exceeded by:0
interrupt: hw used:5, exceeded by:0
Serious Warning: Possible sw stack corruption, function 'FCM_MY_INT' called by more than one asynchronous thread (main/Task, interrupt, interrupt low)
Serious Warning: Possible sw stack corruption, function 'delay_us' called by more than one asynchronous thread (main/Task, interrupt, interrupt low)
Memory Usage Report
RAM available:368 bytes, used:87 bytes (23.7%), free:281 bytes (76.3%),
Heap size:281 bytes, Heap max single alloc:95 bytes
ROM available:8192 words, used:1945 words (23.8%), free:6247 words (76.2%)
success
Return code = 0
FINISHEDWhenever a flowchart is compiled it's always wise to check Call Stack Usage Report
I have found 4 issues with your flow chart.
1 PWM component in MY_INT macro is causing a corruption warning
2) Delay component in FAIL_SAFE macro causing a corruption warning you can use 5 times nop instead = 1us at 19.66MHz.
e.g in a C code box:
asm
nop
nop
nop
nop
nop
Since
3) ADC component in MY_INT is causing stack to exceed 8.
4) may not be an issue since it's accessed before interrupt is enabled: There is a MY_INT being called by a call macro and an interrupt macro.
This would not be allowed if the call macro was after the interrupt macro.
I don't believe its a good idea to have ADC component within an interrupt. I believe its the delays used within ADC component that causes the issues but I could be wrong?
asm
nop
nop
nop
nop
nop
Since
