Having worked for a while with this gLCD 4DSystem, i can work out most of the component(Print, DrawCircle, Touch) macro but seem to not get response when using the:
1)SetBackColor
2)SetForeColor
No change is detected no matter what range of RGB i use....
--The only way i can change the color is changing the default settings--
Any light on the issue, any one with the same issues???
Thank you guys....
