Help needed with Pic18F25J50 RTCC Setup
Desdewit
Has thanked: 25 times
Been thanked: 11 times
Post by Desdewit »
Hi Guys
I want to use the rtcc function of a pic18f25j50 with an external 32.768 kHz clock crystal to keep time & date for a project I'm working on but have no idea on how to set the config bits in flowcode, please point me in the right direction on where and how to start :?:
Desdewit
Re: Help needed with Pic18F25J50 RTCC Setup
Post by Desdewit »
Hi Guys
How can I set & clear the RTCC CONFIGURATION bits from within flowcode without using a c block :?:
Is it possible to simulate the Pic18F25J50 internal RTCC in flowcode :?:
Enamul
Has thanked: 271 times
Been thanked: 814 times
Post by Enamul »
Thank you very much for pointing to the chip. I have been looking for this chip for last couple of months. I will help you in using RTC as I also need that. I am ordering couple of chips for me. When those will arrive I can start with you.
Enamul
University of Nottingham
enamul4mm@gmail.com
Enamul
Post by Enamul »
Here is a skeleton program with correct config..
PIC18f25J50.fcf
(5.5 KiB) Downloaded 236 times
Enamul
enamul4mm@gmail.com
Desdewit
Post by Desdewit »
Hi Enamul
Thanks for the reply. This is a great chip with lots of usefull features :P
