microchip buss
brandonb
Has thanked: 175 times
Been thanked: 173 times
microchip buss
Post by brandonb »
i keep seeing this while looking at memory chips http://ww1.microchip.com/downloads/en/D ... 22076B.pdf is anyone familiar with its applications
Enamul
Has thanked: 271 times
Been thanked: 814 times
Re: microchip buss
Post by Enamul »
HI Brandonb,
You have given a link for a nice device. UNI/O is becoming very important in complex system where we don't want to use CAN to communicate between nearby modules but want moderate-speed and reliable communication between modules.
A system with a microcontroller acting as the master, and other numerous devices attached to the bus as slave peripherals. Data is embedded into the I/O stream through Manchester encoding. The bus is controlled by the master which determines the clock period, controls the bus access and initiates all operations, while all other devices act as slaves. Both master and slave devices can operate as transmitter or receiver, but the master determines which mode is active
Enamul
University of Nottingham
enamul4mm@gmail.com
