Hi all,
I have a friend who isnt able to use his arms, hands. To get him to get around on his own i have made several electronic aids for him. Now i am building a HID with an ecio module.
The project:
On a display most commonly used chars scroll by and when he wants to use a char, he pushes a footswitch.
The ecio sends this char to the pc via usb hid.
I have this all working except the part where i read the value of the variabele (eg dec 65 to display the letter 'A' via print ascii on the display) needs to be converted to the string value 'A' to send via the USB HID.
Is there an algorithm to do such a thing easely, or do i really need to make a string array for all the letters, numbers and symbols.
thanks in advance
ascii to string conversion.
- JonnyW
- Has thanked: 63 times
- Been thanked: 290 times
Re: ascii to string conversion.
Are you asking how to convert the number 65 (say) to the ASCII equivalent 'A' character?
The two forms are equivalent - decimal 65 is ASCII character 'A', or hexadecimal 41 - all are the same thing, just a different representation. If you send byte 65 to a console it will print an 'A'.
If you are asking how to produce a system to scroll through selected letters in order, this is more involved, as it depends what order you want.
To create a string with a single character in it, create an array of 2 characters (the first is your character, the second is the null character to denote the end of the string). Then in a calculation (assuming you are using Flowcode):
This is then a string containing the single character.
Cheers,
Jonny
text[0] = 65 // Or any other character
text[1] = '\0' // Null terminator
Cheers,
Jonny
Thanks Jonny,
Im still struggling with the hid component.
Is there anyone who can get me started with a working usb hid keyboard "hello world" example.
Lets say, i use an ecio28.
When i plug it in or push the reset button, it behaves as an usb keyboard typing "hello world"... Cant get it to work...
Thanks in advance... Davy
- Enamul
- Has thanked: 271 times
- Been thanked: 814 times
Have you tried to use this example?
- Keyboard Demo.fcf
- (24.14 KiB) Downloaded 403 times
kersing
- Has thanked: 553 times
- Been thanked: 1081 times
In the HID component you need key codes, not strings or ascii values. There are two ways to translate the ascii values to key codes, one is to create a table with 128 elements (assuming you do not require special characters). Use the ascii value of the character as index. An example:
keycode[48] = 39 (code for 0 is 39)
keycode[49] = 30 (code for 1 is 30)
keycode[67] = 38 (code for 9 is 38)
keycode[65] = 4 (code for A is 4)
keycode[66] = 5 (code for B is 5)
keycode[90] = 29 (code for Z is 29)
When you need to send the key you simply use the ascii value to index to array and send the result:
xfercode = keycode[index]
(There is no need to fill the table by using an assignment for each element. there are smart ways to initialize the table in one go if you want to go this route.)
The other solution is to do some calculations. The key codes for the characters are consecutive starting at 4 for 'a'/'A'. So if the ascii value of the character to send is between 65 (A) and 90 (Z) subtract 61.
Take a look at this document for the key codes.
― C.S. Lewis
― C.S. Lewis
Ahaaa... Thanks!!! i was trying to send the ascii value of the key pressed, like in the old days. Guess i'm getting old
I'll try, and if i get it to work i'll post the code here...
cheers Davy
cheers Davy
