different way of measuring rpm
brandonb
Has thanked: 175 times
Been thanked: 173 times
Post by brandonb »
i did this project a while back, this is a universal tach for gasoline engines, the responce and accuracy is very good, you can set it for cam or crank, then type in how many teeth are on the tone wheel, then it will give back rpm based on time it took to count the teeth +1 that was input in menu, the update rate is determined by engine speed not a predetermined time, in this way the update rate is a variable of engine rotation http://www.youtube.com/watch?v=BAEJS0CZ ... Wg&index=3 here is flowchart
nerdz univeral tach.fcf
(49.18 KiB) Downloaded 594 times
Enamul
Has thanked: 271 times
Been thanked: 814 times
Re: different way of measuring rpm
Post by Enamul »
Nice work Brandonb :D
Enamul
University of Nottingham
enamul4mm@gmail.com
Just watched the youtube video. your hardware works great!
Good job, and thanks for sharing.
