Play symbol (triangle)
Tony Brown
Has thanked: 36 times
Been thanked: 5 times
Post by Tony Brown »
Anyone know how to print a play symbol (triangle pointing to the right) on a lcd.
Tony
Enamul
Has thanked: 271 times
Been thanked: 814 times
Re: Play symbol (trianlge)
Post by Enamul »
I haven't checked that in hardware but the following link is saying ASCII code 16 should display ►Play (Forward). If you put printascii(16) in LCD macro; you should be able to check whether it print that character or not.
http://www.scribd.com/doc/37032592/ASCII-CHARACTER-CODE
Enamul
University of Nottingham
enamul4mm@gmail.com
dazz
Has thanked: 474 times
Been thanked: 458 times
Re: Play symbol (triangle)
Post by dazz »
Hi Tony
Like enamul i havent tried in hardware , but if you look at the lcd help file it lists the useable characters, the otherway is to find an lcd character generater online and make up your symbol then write that to the display
Dazz
Hi Tony,
This article may help for uploading a custom character to the display.
http://www.matrixmultimedia.com/mmforum ... =26&t=4796
Tony Brown
Thanks all for your help.
I tried the printascii(16) but I did not get the play triangle, I got a cross type shape.
Benj in my flowcode 5 components folder I cannot find the LCDDisplay code. I found LCDDisplay.c but in that file there is no line that says "internal" anywhere.
Attached is a small flowcode file that I made which scrolls through the ascii symbols and if you stop it at 16 you will see what I get.
Tony
ascii_code.fcf
(9 KiB) Downloaded 518 times
Not the arrow but the greater than symbol is PrintASCII(62)
If you want the triangle symbol for play symbol, then I agree with creating custom symbol.
I'm looking into how to do that with V5
Hi Tony,
Can you try this please.
It prints an Play symbol on my LCD
Play Arrow.fcf
(6.5 KiB) Downloaded 513 times
Forgot to add, you will need to change to your target device, and clock speed + correct configuation settings.
Custom LCD char will not simulate. Must be be loaded on to hardware or simulator capable of running hex files.
Tony Brown
Hi Martin
I get nothing on the screen
Tony
Tony Brown
Hi Martin
Just read your last post, is it possible that the ASCII code for the play triangle (16) is not showing up on the flowcode simulation because it will only work on the hardware?
I will try it tomorrow and repost.
Tony
on your hardware?
Will not show in Flowcode simulator
I have altered your file so will show arrow on 16F88.
Both on my hardware and simulator that works with hex files I have:
(80.89 KiB) Downloaded 8570 times
ascii_code V2.fcf
(7.5 KiB) Downloaded 484 times
Tony Brown wrote:is it possible that the ASCII code for the play triangle (16) is not showing up on the flowcode simulation because it will only work on the hardware?
ASCII(16) does not work for me, but it may work with different LCD character sets I don't know about.
I am creating a basic tutorial for creating LCD custom characters.
Its easy to do with V5 (custom code does not require altering on V5, link is for Flowcode V3)
Will also check if it works with V4 as well
Edit Confirmed working with Flowcode 4.
I have created an article on creating custom LCD Characters for Flowcode V4 and V5, which can be found here:
http://www.matrixmultimedia.com/mmforum ... 26&t=11987
Tony Brown
Hi medelec35
Thanks for tutorial that will really be useful, will let you know how I get on.
Your welcome Tony.
Did the play char show on your display ok?
Tony Brown
Am going to try it tomorrow, so will let you know then.
Ok mate, no worries.
Thanks for your reply
Tony Brown
Hi Martin
Got some new pics on order, ran out :-(
Im hoping this works cant wait to try it.
Will let you know how I get on soon.
Tony
Tony Brown wrote:Hi Martin
Don't you just hate it when that happens :(
Nothing much worse then being keen on getting thing sorted as just got a new bit in Flowcode to try and you not got a chip to try it on :cry:
Tony Brown
Hi Martin
Finally tried it, it works great... thanks.
How do I put the triangle where ever I want on the screen?
Tony
glad it works :)
Tony Brown wrote: How do I put the triangle where ever I want on the screen?
Just use normal cursor commands.
E.g Cursor x=5 Y=1
Then use print ASCII with a 0 to display arrow, just like in the flowchart posted.
Tony Brown
Hi Martin
I have found that whilst the play triangle is on the screen (bottom line of lcd), the top line gets blanked out, any idea?
Can you post (Or PM if its commercial) your flowchart please, then I can take a look.
No promises as I have only just worked out how to create custom chars with FC5 after your post.
So i'm no expert on it.
Tony Brown
Hi Martin
Solved it, I had to put the FCD_LCDDisplay0_RAM_Write(0,8,12,14,15,14,12,8,0); right at the beginning of the lcd start up and I can now put the rest of the sequence where ever I want it.
Tony
Hi Tony,
Glad you solved it.
Just for clarity is it right at the beginning of your flowchart, before LCD enable,
or just after led enable before Main loop?
