is the flowcode files for PID at the following location available for flowcode V4?
http://www.matrixmultimedia.com/article.php?a=56
Rgds,
Paul
PID MX009 (Flowcode V4 version of files)
- Enamul
- Has thanked: 271 times
- Been thanked: 814 times
Re: PID MX009 (Flowcode V4 version of files)
In the additional files Flowcode code is given..you should be able to find that.
there is two files in there named:-
"PID_demo.fcf_pic16"
"PID_sim.fcf_pic16"
I'm not sure why there is the ".fcf_16" extension on the files but when I delete the "_16" bit, flowcode V4 can then recognise the file type.
However, when I try to open either file the following message is displayed:-
"Unable to create microcontroller 30F2011 as the definition file 30F2011.fcd is missing or corrupt" .
Paul
"PID_sim.fcf_pic16"
Paul
Hi Paul,
Leave the file extension as it was and then use the file -> import menu to allow you to open the files.
The files were basically written using Flowcode for dsPIC but can be loaded into any other variant of Flowcode by using the import menu.
