EB037 error when using FAT Component
Mark
Has thanked: 20 times
Been thanked: 16 times
Post by Mark »
I have loaded the latest version of Flowcode 5.5.2.1 and have been trying to use the EB037.
After trying the example programs (although not with the ECIO) as such and then trying
with one of John Crow's dual temp logger (again using a PIC18F4455) and lastly trying a
PIC 18F2610 with its simpler clock setting and starting from scratch. In every instance
I can get the chip working but whenever the FAT component is added I get:
Error: Unresolved external function:'FC_CAL_SPI_Set_Prescaler_1(unsigned char)'
Error: Unresolved external symbol, function:FC_CAL_SPI_Set_Prescaler_1
failure
Return code = -2
Flowcode was unable to assemble the ASM file due to the following errors:
I have tried fiddling around with the component connections.
Any suggestions where things have gone wrong?
The skeleton that works without the FAT macro and with the FAT macro fault is:
SD Card Test.fcf
(12 KiB) Downloaded 318 times
The full errors are:
Errors.txt
(1.51 KiB) Downloaded 300 times
Thanks in advance,
Mark
Go with the Flow.
Re: EB037 error when using FAT Component
Hi Mark,
I've just tried it here and it's compiling ok for me. Here are the files I'm using.
This file goes into the components directory.
FC5_PIC_FAT16.c
(59.6 KiB) Downloaded 331 times
And this file goes into the CAL/PIC directory.
PIC_CAL_SPI.c
(14.37 KiB) Downloaded 333 times
Mark
Post by Mark »
Ben,
Thanks, the error mesage has gone.
Mark
Go with the Flow.
