Hi i have a compiling error
CHIP: PIC18F26J53
FLOWCODE 5.0 VERSION 5.4.0.0
C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_UART.c(521): error: left operand must be l-value
C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_UART.c(521:13): error: failed to generate expression
C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_UART.c(522): error: left operand must be l-value
C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_UART.c(522:13): error: failed to generate expression
What should i do to fix this because i urgently need to use UART2?
I am also trying to use the Peripheral Pin Select feature
Thank you
1826j53 UART2 PROBLEM
ProtonLaser
- Has thanked: 6 times
- Been thanked: 2 times
Re: 1826j53 UART2 PROBLEM
What pins would you like the UART2 connected to and I will see if I can fix the file to route to these pins for you.
ProtonLaser
Can RX2 be anything for now or do you have a free I/O pin in mind I can assign it to?
I have re-routed TX2 to RP1 and RX2 to RP0 in this CAL file.
Copy the file to your "Flowcode/v5/CAL/PIC" folder and the compilation should then go through correctly.
Here are the lines of code that control the remapping, line number 525 in the C file.
RPOR1 = 6; //TX2 - RP1 - RA1
RPINR16 = 0; //RX2 - RP0 - RA0Regards Ben Rowland - MatrixTSL
ProtonLaser
I have tryed what you said, copied the file into my folder, and compiled again using the second UART, and the same problem appears.
I have posted my program, to see if there is something i am doing wrong in my code.
Thanks.
Thanks.
- flow_CCP4_polling.fcf
- (15.91 KiB) Downloaded 266 times
Ah sorry about that, I had capitalised the register names and they should be in lower case,
This one should work correctly.
- PIC_CAL_UART.c
- (25.86 KiB) Downloaded 276 times
ProtonLaser
